Re: Power steering on 400
Posted by Redrider on February 09, 2006 at 21:20:14 from (66.235.45.149):
In Reply to: Power steering on 400 posted by DEWAYNE UTRUP on February 09, 2006 at 09:42:06:
Where did you put the plug? The plug goes between the first hydratouch valve and tower. What this does is give the power steering priority over you hydratouch valves. If this plug is in the wrong place you will not be forcing hydraulic fluid to you hydraulic motor until a valve is pulled.
