Re: Starter Soleniod ?????
Posted by old on February 10, 2006 at 17:07:08 from (207.69.137.40):
In Reply to: Starter Soleniod ????? posted by Tweeter on February 10, 2006 at 16:03:32:
You can use a soliniod from a ford car/truck from say around 1970. Your problem is that it has started the tractor a few to many times and has started to burn the point in there and that is what causes it to stick. I'd run a hot wire from the battery to the coil to see if it will run that way. If it does then you have a bad wire or bad switch which could also be your soliniod problem.
