Re: Note for Old Dutch 656 ring gear
Posted by Old Dutch on February 11, 2006 at 20:13:55 from (66.191.117.211):
In Reply to: Note for Old Dutch 656 ring gear posted by Yellott Canby on February 11, 2006 at 09:50:19:
Yellott:
If the shimming helped as far as the grinding noise we know that was part of the problem. Shouldn't be binding and staying engaged anymore as you have shifted that point. The hanging in seems to indicate either a sprung starter armature shaft, or damaged splines on the armature shaft, or drive. Maybe both. I would remove the starter and try it on the bench and see if it is moving in and out the way it should by activating it with a battery. Make sure it is clamped so it stays put. Their is a fairly heavy spring that moves the drive back when not engaged. Maybe broken, or the actuating fork that moves the drive ahead could be binding. Sorry I didn't get back to you sooner. Been a busy day running.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
