Re: Torque amplifier repair?
Posted by Larry806 on February 12, 2006 at 18:52:45 from (70.61.182.1):
In Reply to: Torque amplifier repair? posted by Tired 300 in Mn on February 12, 2006 at 17:11:15:
I went through 3 torque's week before last SMTA , 400 & SMTA D the most I had in one was 165.00. You can get the rubber plugs , springs, and pins from a IH dealer. The rollers aren't available. Tractor Vet said you can get them from Timken I got lucky & found some NOS. When you order the gasket & seal kit ( Hy Capacity) you have to order two other gaskets I can get the part number if you need it ( both the same)
2 of them had the nut that holds the TA flywheel backed off the locking tab had broken. I went ahead & went through the ramp & rollers anyway while I was in there
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
