Re: Super C too hott!!!
Posted by Janicholson on February 13, 2006 at 06:01:02 from (199.17.6.175):
In Reply to: Re: Super C too hott!!! posted by Andrew Z on February 13, 2006 at 05:26:47:
Possible problems include:
Low % of antifreeze. 50/50 (normal)or 60%
Antifreeze, and 40 % water for the strongest mix. Check it with a float type tester.
Collapsed hose (internal break)
Plugged up core (look in with a good light at the top of the tubes)
loose impeller on water pump (happens)
Good luck finding it,
JimN
