Re: Super A Carb.
Posted by scotty on February 13, 2006 at 10:42:46 from (199.231.49.128):
In Reply to: Super A Carb. posted by Joe Kelly on February 13, 2006 at 09:18:03:
Hi Joe,
I believe they used three different types of carb on the Super A. Zenith, Marvel Schebler, and one other which Im having a senior moment on. My Super A has the Zenith. Take it of clean it up and you should be able to identify which you have. You can find rebuild kits on this site. Good luck!
scotty
