Re: Super A Carb.
Posted by Joe Kelly on February 13, 2006 at 10:49:43 from (199.125.55.250):
In Reply to: Re: Super A Carb. posted by scotty on February 13, 2006 at 10:42:46:
Thanks for the reply Scotty.....I thought if only one particular carb was used I could get a kit in hand before removing the carb...and hopefully do the job all at one time. I think the other possibility for the carb supplier might have been Carter...but not sure.
Thanks again for your help.
Joe
