Re: Super M disc brakes
Posted by JRD(VA) on February 15, 2006 at 05:14:13 from (64.12.116.65):
In Reply to: Super M disc brakes posted by Jim in NC on February 15, 2006 at 04:30:19:
The balls in between the metal center disc might have flat spots causing it to remain open, also look for wear or dirt and rust on the splines of the shaft and disc.
