Farmall Tractors Discussion Board
Re: Engine timing on M
Posted by Phil Auten on January 08, 2000 at 19:15:18 from (206.175.72.226):
In Reply to: Engine timing on M posted by Jeff K on January 08, 2000 at 18:46:32:
Jeff,
There are two notches in the rear flange of the crankshaft pulley. #1 piston is at TDC when the first mark is aligned with the pointer on the crankcase front cover. It's timed properly then.
Standing on the distributor side of the engine, the crank pulley marks will be moving away from you since the crank rotates clockwise as viewed from the front. I think you'll understand it when you see it.
Phil
Post A Followup
: Re: Re: Engine timing on M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
