Farmall Tractors Discussion Board
Re: Re: Engine timing on M
Posted by jeff on January 08, 2000 at 19:58:35 from (205.188.193.39):
In Reply to: Re: Engine timing on M posted by Phil Auten on January 08, 2000 at 19:15:18:
i allways find top dead center then mark the pully,wen you get base timing set,open throtle and set total at around 38 degreze,you will need a ajustible timing light.
Post A Followup
: Re: Re: Re: Engine timing on M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
