Re: Farmall H Drive shaft bearing and countershaft
Posted by farmallhal on February 15, 2006 at 14:03:43 from (64.24.35.16):
In Reply to: Re: Farmall H Drive shaft bearing and countershaft posted by shagle on February 15, 2006 at 09:09:45:
Driving/transmission shaft, rear, ST293 bearing, seal not required on rear. Front, both ST206 and ST247 bearings, 70258D seal and 47894D and 47896D gaskets.
Counter shaft, front, ST246 bearing, 43308D seal and 47873D gasket.
Pilot Bearing, 43356DA.
These part no's. are from my TC-27E Parts Catalog for H and HV tractors as issued in Feb. 1960. Hope this helps and where are you located? Good Luck in your repair, Hal
