Re: Super C loader questions
Posted by shawn138 on February 15, 2006 at 14:08:53 from (65.30.57.56):
In Reply to: Re: Super C loader questions posted by Nat 2 on February 15, 2006 at 10:44:58:
Left out a crucial element and I don"t know what it does to your scheme. The cylinders on the loader are single acting so the first valve has only one port, the second valve has two ports.
Also, when you direct me to connect to the pressure in on the touch controll, is that done by removing the plug on the line housing and connecting there. I assume I need to leave the lines on the tractor that connect the tractor"s resevoir to the pump, correct?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
