Re: F20 timing marks
Posted by canetractor on February 15, 2006 at 17:19:59 from (216.78.99.200):
In Reply to: F20 timing marks posted by Scott In Indiana on February 15, 2006 at 16:01:58:
It is easy to miss, Small hole, large flywheel and crud. One method is removing spark plugs 2,3,4 and turn engine with crank until compression is felt. Then continue until the dowl pin in the end of crankshaft is horizontal. If mag is properly timed and lever retarded you should hear click as DC is in view. Cleaning flywheel may be necessary.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
