F20 timing marks
Posted by Scott In Indiana on February 15, 2006 at 16:01:58 from (63.87.170.72):
I've been reading the archived posts about timing marks on the F20 flywheel. Everything I've read indicates there's a "DC" somewhere on the flywheel that indicates No. 1 cyl at top dead center. I can't seem to find this DC on mine but did notice what appears to be a hole about 1/2" in diameter drilled through the flywheel. This hole shows up in the bell housing on the left side where I'm supposed to look for the "DC". Were some of them marked with a hole instead?
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
