Re: F20 timing marks
Posted by El Toro on February 15, 2006 at 18:54:00 from (64.12.116.65):
In Reply to: F20 timing marks posted by Scott In Indiana on February 15, 2006 at 16:01:58:
When you remove No1 sparkplug, hold your thumb over the hole until you feel compression, then drop that screwdriver with a big handle into the cylinder. You will need someone to crank until you feel compression. Once you reach TDC on the compression stroke your timing mark should be
there. May be covered by rust and oil/dirt.
Hal
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
