quick fix wisconsn
Posted by mark k on February 15, 2006 at 21:07:32 from (64.19.109.193):
In Reply to: quick fix wisconsn posted by all for school on February 15, 2006 at 08:22:23:
Hello,
When I was trying to start mine for the 1st time I used the orig tank and a boat fuel bulb, I later found out it had a priming lever. I don't know whether it will flow through the pump or not. With the bulb you can push it through unless there is a hole in the diphram and it lets it run out the hole in the pump. Mark
