Re: Farmall H Rear Wheels extension
Posted by williamf on February 16, 2006 at 08:21:23 from (69.19.14.12):
In Reply to: Farmall H Rear Wheels extension posted by Ryan in PA on February 16, 2006 at 07:28:53:
Others covered the tread direction, you seem to have got that with the application of coffee.
I'm not sure about the maximum width after you switch them around, but it's about 8 feet.
As for "How HARD is it to get those wheels off? jsut loosen th 2 bolt that i see on the inside? What about the wheels weghts are they hard?" weel, that depends. Sometimes they come easy, sometimes people write about having to go get their acetelyne tanks refilled. It's a rust and torque thing.
The weights are about 145lbs each. After you get them off you'll see that there are 4 bolts on each hub, I think you're not seeing the ones behind the weghts.
Good Luck, and Cowman's right, they look better the other way.
Wm
