Re: Farmall H Rear Wheels extension
Posted by CNKS on February 16, 2006 at 14:48:39 from (204.249.178.138):
In Reply to: Farmall H Rear Wheels extension posted by Ryan in PA on February 16, 2006 at 07:28:53:
Maximum width with standard axles is 80 inches center of one tire to center of the other. Do not try to take off those wheels without help. If you work alone use an engine hoist. Even then they can tip over. If you use a hoist take the weights off first -- unless you are a pro football player. They will squash you pretty good if you slip and fall.
