Re: Super A carb??
Posted by Jack in Ohio on February 17, 2006 at 06:41:50 from (192.31.106.34):
In Reply to: Re: Super A carb?? posted by RustyFarmall on February 17, 2006 at 05:51:47:
So what is the difference between the Zenith 11115 and the Zenith 10514A? Those are the models listed here on YT for rebuild kits. The parts manual doesn't list those numbers.
Jack
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
