Re: Cub 185 Overhaul
Posted by Roger46 on February 17, 2006 at 17:39:09 from (69.58.143.31):
In Reply to: Cub 185 Overhaul posted by dhermesc on February 17, 2006 at 14:12:12:
I just completely overhauled a cub engine. I did all the disassembly and reassembly myself, so had quite a few hours into it. Cubs can be expensive to overhaul because they do not have sleeves, so you have to bore out if worn. I spent $900 at NAPA shop getting the mains and rod bearing housings trued up, head and deck planed, block hot solvent dipped, and valves replaced and ground. I didn't have to have the cylinders bored or get new pistons, I only needed new rings as the previous owner had done a half job on an overhaul. Secondly, you can spend another $400 on rebuilt carb and magneto. If you add labor to it I could see where you could get to the $3000+ number. Roger
