Farmall Tractors Discussion Board
Re: Re: Farmall A Exhaust Lift
Posted by Chris Auer on January 09, 2000 at 08:58:15 from (152.163.207.54):
In Reply to: Re: Farmall A Exhaust Lift posted by Curt Cooke on January 08, 2000 at 20:07:18:
Curt,
By not working well, you must mean fairly low pressures were shunted into that cylinder, to not smother the engine with back pressure. I'd like to know how much tension winds up on those cables, versus a hydraulic lift - if a guy stood on the plow, would it still lift? Im sure an IHC engineer from 1948 could've told us all about it.
Post A Followup
: Re: Re: Re: Farmall A Exhaust Lift
