Farmall Tractors Discussion Board
Re: Re: Re: Farmall A Exhaust Lift
Posted by Jim Becker on January 09, 2000 at 10:46:58 from (209.30.171.172):
In Reply to: Re: Re: Farmall A Exhaust Lift posted by Chris Auer on January 09, 2000 at 08:58:15:
When they were new, they worked pretty well. But rust, corrosion and deteriorating rubber parts made them loose power pretty quickly. With everything in pretty good shape, they had pretty good power. It would probably lift the plow with someone standing on it, but not with much margin.
If the diverter valve on the manifold is in decent shape, it will stall the engine (even at full throttle).
Post A Followup
: Re: Re: Re: Re: Farmall A Exhaust Lift
