Re: farmall 400 freed up
Posted by farmall 460 puller on February 19, 2006 at 04:33:01 from (205.188.116.133):
In Reply to: farmall 400 locked up posted by farmall 460 puller on February 17, 2006 at 16:58:59:
well the tranny fluid and wd 40 worked .didnt take much to loosen it.like i said with the plugs out and the rocker arms removed it spun with the starter ,made a big mess though (oh well),but after i spun it over a while with the starter there was antifreeze on top of the head?????
next i will see if i have sprk and try to get it going .i believe it will need an engine kit.
the tractor is tight and beautifull.
thanks im alittle worried about the antifreeze????
when i was spinning it over with the starter i had the oil psi gauge half way up
