Re: 966
Posted by the tractor vet on February 19, 2006 at 05:55:13 from (64.179.117.186):
In Reply to: 966 posted by T.L. IH on February 18, 2006 at 20:52:14:
It could be that the clutch pack is shot and pressure is low on the adjustment ( takes special fitting to check pressure ) Or it could be that the splines on the input shaft are going out to lunch and that will require a new clutch pressure plate and PTO input and bearing and seals and a split. Since i can not check it out myself it could be a minor problem of pulling the PTO unit out and throwen in a new set of clutches and setting the pressure up to a split and a main clutch job. OR both .
  • Re: 966 GFordoSD 07:29:52 02/19/06 (1)
    • Re: 966 Aces 10:20:50 02/19/06 (0)
