Re: O.T. block heater
Posted by Hugh MacKay on February 19, 2006 at 07:56:13 from (209.226.247.157):
In Reply to: Re: O.T. block heater posted by GordoSD on February 19, 2006 at 07:27:20:
Gordo: I probably should have said pull the vehicle outside. I figured most folks would have the common sence not to try that in a building. I have started many a diesel that way far from any electricity and I'll grant you never any failures. All you need is a sheet of plywood on the wind side. I repeat NO OIL LEAKS, and never on a gas engine.
