Re: Not wanting to come off
Posted by Bob from IL on February 19, 2006 at 12:12:41 from (205.188.116.133):
In Reply to: Not wanting to come off posted by Lane on February 19, 2006 at 09:33:40:
yugrotcart is right if the tractor is locked in 2 gears just pull shifter pin and center slots
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
