Re: turbo-ing a 560 redneck style
Posted by JakeF on February 19, 2006 at 20:06:08 from (64.146.188.222):
In Reply to: turbo-ing a 560 redneck style posted by Chris Brown on February 19, 2006 at 18:11:57:
Just tap into the oil galley and run a 1/4" line to the turbo and a 3/4" drain line to the fuel pump drive gear access hole. The car turbo you have is probably bigger than you need, but will likely only make about half the boost you want. Gassers usually only run 6-10PSI. Figure out how many CFM the car motor was moving at 5500RPM and ???150 CID verses your 282CID at 2500RPM. It'll work if you keep it in the range of boost it was meant to work at.
