Re: Wiring Question...
Posted by Janicholson on February 20, 2006 at 13:21:17 from (199.17.6.175):
In Reply to: Wiring Question... posted by Iowaboy on February 20, 2006 at 12:45:45:
One 10ga. wire comes from the starter switch (battery side, not starter side). that wire hooks to the amp meter, and that should be the only wire on that side of the amp meter. (use good terminal ends)
The other side of the amp meter has a wire (12ga) that feeds the igniton switch (if coil/points), and another wire (10ga.) going to the Bat terminal on the regulator (or the big terminal on the alternator if so equipped), and another wire (12 ga.)going to the light switch.
If, when hooked up, the amp meter reads + when not running with the lights on, (hook up a light temporarily) then move all wires to opposite terminals on the amp meter. It will not hurt the gauge to be backwards. Leave enough wire to switch them if needed.
JimN ---P.S. Bob M's wiring diagrams are great.
