Re: 400 Weak Fast Hitch
Posted by El Toro on February 21, 2006 at 09:39:57 from (64.12.116.65):
In Reply to: 400 Weak Fast Hitch posted by AdamD on February 21, 2006 at 08:29:03:
I would change that hydraulic oil to make sure
there's no moisture in the oil. That may be freezing and causing your problem. Hydraulic
oil shouldn't get that thick. My tractor has hydrostatic drive with hydraulic lift. I use Dextron automatic transmission fluid. This is
the 35th year for tractor. Hal
