400 Weak Fast Hitch
Posted by AdamD on February 21, 2006 at 08:29:03 from (64.184.6.242):
Looking for some suggestion here. The Fast Hitch on my 400 doesn't want to operate at all when it gets around freezing. I know that the hyd. oil (which is not low in the tank) is going to be really thick but it should still be able to do something. It won't lower or raise with or without a load on it. Just makes a type of vibrating noise when level is moved. In warmer weather, it will lift a three bottom plow but is slow at it. What are some of the possible causes to this? Don't know if it helps or not but this is the fast hitch that has the 2-cylinders on it and tractor has power steering that makes a humming noise.
