Re: 400 Weak Fast Hitch
Posted by Nat 2 on February 21, 2006 at 11:07:03 from (64.80.108.53):
In Reply to: 400 Weak Fast Hitch posted by AdamD on February 21, 2006 at 08:29:03:
I think there's a filter screen underneath a cover on the side of the steering pedestal/hydraulic reservoir. It's a round cover held on by four bolts. That may be clogged.
Hydraulic fluid should not be "really thick" in cold weather. ThickER than normal, but not molasses-in-January thick. If your fluid is thick like that, then you've got the wrong stuff in there. Get yourself some genuine CaseIH Hy-Tran and change the fluid once you've cleaned the screen.
