Re: Isocyanates
Posted by jaybird2 on February 22, 2006 at 10:48:24 from (199.103.143.97):
In Reply to: Isocyanates posted by CNKS on February 22, 2006 at 06:42:13:
Thanks for the heads up. I've seen you desperately trying to warn people on posts for quite some time now. I haven't yet gotten to the point where I am ready to paint my first restoration (I've got two that should be ready by spring/summer when it warms up around here in MN) So my question to you is...since I know I want the qualities of a hardener on my sheet metal, and since supplied air systems are quite expensive, is it cost-beneficial to have a body shop paint my sheet metal? I would do the cast myself unless assuming that I don't necessarily need hardener on the cast portions of the tractor. I know this question should probably go into the other forum but I'm a Farmall guy!
