Re: Isocyanates
Posted by CNKS on February 22, 2006 at 17:32:28 from (204.249.178.138):
In Reply to: Re: Isocyanates posted by jaybird2 on February 22, 2006 at 10:48:24:
I can't answer the cost-benefit thing. I suppose the sheet metal wouldn't cost much if you prepped it yourself -- provided you find someone who will do a small job (big for me) such as that. Supplied air costs about $500 more or less -- in your current situation that is $250/tractor. You will probably want to paint more, thus spreading the cost out. Once you use hardener I doubt if you will want to go back to unhardened paint. HOWEVER if you don't use hardener on the cast and do have the sheet metal done with hardener you and the body shop should use the same brand of paint both with and without hardener. If you use IH 2150 on the cast and the body shop uses PPG 71310 acrylic enamel or acrylic urethane on the sheet metal, I can about guarantee you they won't match.
