Battery size
Posted by Randy G. on February 22, 2006 at 17:32:49 from (69.66.189.166):
I"d like to put a 12 volt battery in an original battery box on my 1940 H. Currently it has a large battery on a home made tray leaving the battery exposed to the elements. Would a 12 volt battery small enough to fit in the battery box have enough cold cranking power to work ok? (350-450 CCA"s) The tractor is used for light duty only. Your suggestions are welcome!!! Thanks, Randy
