Re: Furrow Wheel - 311 Plow
Posted by Farmall Frank on February 24, 2006 at 13:22:59 from (69.76.145.131):
In Reply to: Re: Furrow Wheel - 311 Plow posted by Hugh MacKay on February 24, 2006 at 10:44:38:
Thanks, Hugh. I cleaned up the unit, pounded out the pin, and it all came apart. Some of the numbers are: 521155R1, 521156R1, 521165R1, and 521166R2. These are the bearings and hubs, etc.
You are right, these cannot be adjusted.
I would also be interested in the parts diagram for the unit with a rubber wheel, as I just found one that I will get tomorrow. It has real bearings instead of bushings.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
