Re: CUB STARTER
Posted by Kevin Bismark on February 24, 2006 at 17:01:51 from (152.163.100.65):
In Reply to: CUB STARTER posted by FLOPGUNS on February 23, 2006 at 18:09:15:
Can you put this starter in the tractor and hook it up to 6 volts, you may find out that way, been too many years since I had one apart to tell you for sure what to look at, but would think a 12 volt one on 6 volts would barely turn the engine
