CUB STARTER
Posted by FLOPGUNS on February 23, 2006 at 18:09:15 from (204.116.66.170):
I BOUGHT A OLD CUB FROM A FRIEND THAT HAD IT FOR TWO YEAR. IT'S GOT A 12V BATTERY IN IT WITH NEG GROUND AND A GENERATOR. MY QUESTION IS,[ CAN THIS BE A 12V STARTER AND HOW DO YOU TELL THE DIFFERNCE IN A 6V AND 12 V STARTER ? ] I GOT ANOTHER STARTER THAT I TOOK OFF OF ANOTHER CUB PUT IT ON IT AND WHEN I TRIED TO HOOK UP A SMALL JUMPER WIRE TO THE STARTER POST THAT THEY HAD RUN TO THE SWITCH I GOT SOME SPARK ON IT SO I SWICHED THE BATTERY AROUND TO POSTIVE GROUND AND IT WORKED FINE. I ASUME THAT THE STARTER WILL WORK BOTH WAYS. THANKS FLOPGUNS
