Re: Farmall M is it - or+ ground???
Posted by El Toro on February 25, 2006 at 16:45:20 from (64.12.116.65):
In Reply to: Re: Farmall M is it - or+ ground??? posted by Joe Bly on February 25, 2006 at 16:32:21:
Take a look at the old battery cables to see which
cable one is the ground cable. Should be connected to tractor frame. There's a difference in the hole size for connecting your battery cables to the battery. The cable with the larger hole is for the positive terminal. If
your ground cable has the larger hole your tractor is still using + positive ground. Hal
