Re: '49(+-)International Harvester 340 Utility - S
Posted by CHRISCO on February 25, 2006 at 17:21:13 from (198.70.4.31):
In Reply to: '49(+-)International Harvester 340 Utility - Steer posted by sully sulliban on February 25, 2006 at 16:25:57:
I HAD A SIMMULAR PROBLEM BUT MY POWER STEARING PUMP WAS PIGGY BACKED WITH THE REGULAR PUMP BUT I REPLACED THE PUMP AND IT WORKED FOR A WHILE AND FOUND OUT THERE WAS A SEAL CAUGHT IN TH PRESUER RELEAFE AND I REPLACED THE SEAL IN THE RACK CYL IF YOU HAVE ONE OR DO YOU HAVE A CYL?
