Re: Farmall M is it - or+ ground???
Posted by Hermit on February 25, 2006 at 17:57:24 from (69.21.48.104):
In Reply to: Farmall M is it - or+ ground??? posted by Joe Bly on February 25, 2006 at 15:02:31:
If the rest of the wiring system is set up correctly, look at the coil. If the wire to the distributor is connected to the - post then it's a negative ground. If the wire to the distributor is connected to the + post, then it's a positive ground.
