Re: hydraulics, unusual farmall A
Posted by Hugh MacKay on February 26, 2006 at 16:16:01 from (216.208.58.174):
In Reply to: hydraulics, unusual farmall A posted by kazenza on February 26, 2006 at 13:20:34:
kazenza: One item Jim and gene have not told you, is for factory SA hydraulics the top of the torque tube is flat between battery and bell housing, whereas the A torque tube is round on top. You didn't indicate that item one way or the other. Since you have the hole in block for mounting pump, might you also have a flat top torque tube? If you have both, it's just a matter of adding a Super A hydraulic system.
