Re: Farmall 350 Front Loader?
Posted by Nat 2 on February 27, 2006 at 13:04:31 from (64.80.108.53):
In Reply to: Farmall 350 Front Loader? posted by Ken(IL) on February 27, 2006 at 12:04:33:
Got a welder and a torch? It's not a bolt-on affair, but I'm sure it could be modified to fit.
Your 350 should already have at least two hydraulic remotes, plumbed exactly where you'd need them to hook up a loader with hydraulic tilt bucket (up under the gas tank). Unless you're looking for super-fast cycle times, and you're going to use the loader a LOT (in which case you should be getting a skid steer or dedicated loader tractor anyway) you shouldn't need a PTO-driven pump. The built-in live pump should be just fine.
