Re: M axle interchangeability
Posted by NDS on February 27, 2006 at 17:04:11 from (64.12.116.65):
In Reply to: M axle interchangeability posted by beastman on February 27, 2006 at 13:23:25:
The bull gears can be removed and replaced through PTO opening but personaly I had rather remove deck cover than try to wrestle them on through the small hole. Since you would be removing both of them I would be bleeding fron tip of fingers to elbow and run out of cuss words if I was trying to work them through hole. Would guess they weigh close to 50 lbs each. Just my opinion.
