Re: 1066 3 point control lever adjustment
Posted by IaGary on February 28, 2006 at 06:39:09 from (69.63.16.192):
In Reply to: 1066 3 point control lever adjustment posted by Michael Sheik on February 28, 2006 at 05:37:10:
If you look under the platform from the rear you will see the bottom of the levers on a pivot point.
Reaching with a socket and an extension you can tighten the lever pivot point.
It doesn't take much tighting to cause more friction.
Good luck
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
