Re: M's not starting...
Posted by Marlin M '51 on March 05, 2006 at 03:33:19 from (12.218.126.31):
In Reply to: M's not starting... posted by Farm-all-the-way on March 04, 2006 at 12:32:22:
Make sure you have battery voltage (12 or 6) AT the coil. Low voltage (bad switch) will cause this problem.
