Re: Farmall H Rear Wheel adjustment.
Posted by Dave BN on March 05, 2006 at 14:01:05 from (64.12.116.65):
In Reply to: Farmall H Rear Wheel adjustment. posted by Ryan in PA on March 04, 2006 at 15:35:59:
Randy, those weights are meant to be on the outside of the wheel so I'd take them off if I could. Be careful as they weigh about 150lbs each and are champion finger smashers. The weights for the inside of the wheel are split into two halves so you can put them on around the axle. That would be if you wanted to add more than what would fit on the outside of the wheel. You can stack up to 4 on the outside of each back wheel. Dave.
