Re: Farmall A Overheating
Posted by El Toro on March 06, 2006 at 04:20:00 from (64.12.116.65):
In Reply to: Farmall A Overheating posted by Adam IH on March 05, 2006 at 20:26:04:
You need to check the radiator tubes for being clogged. Permanent antifreeze will cause this
if you lose the rust inhibitor. This usually requires a radiator shop to rod out the tubes.
It may be cheaper to go with a new radiator if this is the problem. Hal
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
