Re: Hydraulic leak from differential lock on a IH-
Posted by bbwhite1 on March 06, 2006 at 10:05:49 from (207.111.160.28):
In Reply to: Hydraulic leak from differential lock on a IH-424 posted by bbwhite1 on March 01, 2006 at 06:00:41:
Tim,
I replaced the seal on the differential lock shaft over the week-end. You push back the metal sleeve surrounding the shaft and block it in place with a dowel, piece of wood, bolt etc.
Remove the snap ring on shaft and then the dowel. The sleeve will come off. There's an o-ring on sleeve. That's the only seal for my differential lock. I screwed up the snap ring on mine so I've got to get another one.
I'm not sure if you can remove the diffential housing, slide it over the shaft and replace the other gasket and seal or not.
Hope this helps.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
