Re: Farmall H stability??
Posted by Nat 2 on March 06, 2006 at 14:10:09 from (64.80.108.53):
In Reply to: Farmall H stability?? posted by Guyzoo on March 06, 2006 at 11:08:47:
I'm gonna be another one who says it can be done, but you've got to be smart about how you do it, or you'll end up eating chain.
The key is leverage. Most people equate pulling stumps to cutting the tree off level with the ground, wrapping a chain around it, then tugging and jerking with the tractor for all its worth until the chain breaks or the stump comes loose.
Small trees, about the size you're pulling, work best if you leave a stump at least 4-5 feet tall. Wrap the chain around the top, and it'll tip over easy as pie. If the chain breaks, it's going to head straight for the ground, but it won't break because you're not putting a fraction of the tension on it that you would using brute force.
Once the stump is tipped over, you can hack away at the remaining roots until it's free, then drag it away.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
