Farmall H stability??
Posted by Guyzoo on March 06, 2006 at 11:08:47 from (142.166.236.135):
Hi, I would like to know if a farmall H with a wide front end is stable. I bought this tractor this winter with a snowplow but today, after removing the snow plow, I found that the front end seems pretty light. It has NO fluids in the tires. I will have to remove stumps this spring with it. The stumps are no more than 4-5 inches in diameter. I know my Allis-Chalmers WD was doing pretty good removing those stumps last fall but she is going thru a full restoration right now. Any advices from experts would be really appreciated since I am only 17 years old.
THANKS A BUNCH
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
